I am having problem to open idf file created by v9.0 by IDF editor for v9.0.
I got error message as below.
I tried to investigate the reason opening in texteditor but could not find reason.
Could anyone tell me how I can try to solve this problem?
I also added part of the idf file content where having problem.
idf file
WindowShadingControl,
No Shade, !- Name
1212-Office-TZ, !- Zone Name
1, !- Shading Control Sequence Number
InteriorShade, !- Shading Type
, !- Construction with Shading Name
AlwaysOff, !- Shading Control Type
, !- Schedule Name
, !- Setpoint {BasedOnField A5}
No, !- Shading Control Is Scheduled
No, !- Glare Control Is Active
NRDC Interior Shade, !- Shading Device Material Name
, !- Type of Slat Angle Control for Blinds
, !- Slat Angle Schedule Name
, !- Setpoint 2 {BasedOnField A5}
, !- Daylighting Control Object Name
Group, !- Multiple Surface Control Type
Sub Surface 43, !- Fenestration Surface Name 1
Sub Surface 10, !- Fenestration Surface Name 2
Sub Surface 16, !- Fenestration Surface Name 3
Sub Surface 2, !- Fenestration Surface Name 4
Sub Surface 19, !- Fenestration Surface Name 5
Sub Surface 23, !- Fenestration Surface Name 6
Sub Surface 6, !- Fenestration Surface Name 7
Sub Surface 5, !- Fenestration Surface Name 8
Sub Surface 22, !- Fenestration Surface Name 9
Sub Surface 25, !- Fenestration Surface Name 10
Sub Surface 31, !- Fenestration Surface Name 11
Sub Surface 20, !- Fenestration Surface Name 12
Sub Surface 32, !- Fenestration Surface Name 13
Sub Surface 35, !- Fenestration Surface Name 14
Sub Surface 38, !- Fenestration Surface Name 15
Sub Surface 1, !- Fenestration Surface Name 16
Sub Surface 9, !- Fenestration Surface Name 17
Sub Surface 26, !- Fenestration Surface Name 18
Sub Surface 40, !- Fenestration Surface Name 19
Sub Surface 4, !- Fenestration Surface Name 20
Sub Surface 17, !- Fenestration Surface Name 21
Sub Surface 36, !- Fenestration Surface Name 22
Sub Surface 42, !- Fenestration Surface Name 23
Sub Surface 44, !- Fenestration Surface Name 24
Sub Surface 45, !- Fenestration Surface Name 25
Sub Surface 46, !- Fenestration Surface Name 26
Sub Surface 41, !- Fenestration Surface Name 27
Sub Surface 47, !- Fenestration Surface Name 28
Sub Surface 48, !- Fenestration Surface Name 29
Sub Surface 14, !- Fenestration Surface Name 30
Sub Surface 49, !- Fenestration Surface Name 31
Sub Surface 50, !- Fenestration Surface Name 32
Sub Surface 27, !- Fenestration Surface Name 33
Sub Surface 28, !- Fenestration Surface Name 34
Sub Surface 90, !- Fenestration Surface Name 35
Sub Surface 53, !- Fenestration Surface Name 36
Sub Surface 91, !- Fenestration Surface Name 37
Sub Surface 112, !- Fenestration Surface Name 38
Sub Surface 51, !- Fenestration Surface Name 39
Sub Surface 60, !- Fenestration Surface Name 40
Sub Surface 64, !- Fenestration Surface Name 41
Sub Surface 83, !- Fenestration Surface Name 42
Sub Surface 87, !- Fenestration Surface Name 43
Sub Surface 89, !- Fenestration Surface Name 44
Sub Surface 99, !- Fenestration Surface Name 45
Sub Surface 103, !- Fenestration Surface Name 46
Sub Surface 106, !- Fenestration Surface Name 47
Sub Surface 108, !- Fenestration Surface Name 48
Sub Surface 54, !- Fenestration Surface Name 49
Sub Surface 59, !- Fenestration Surface Name 50
Sub Surface 109, !- Fenestration Surface Name 51
Sub Surface 93, !- Fenestration Surface Name 52
Sub Surface 57, !- Fenestration Surface Name 53
Sub Surface 62, !- Fenestration Surface Name 54
Sub Surface 74, !- Fenestration Surface Name 55
Sub Surface 139, !- Fenestration Surface Name 56
Sub Surface 133, !- Fenestration Surface Name 57
Sub Surface 135, !- Fenestration Surface Name 58
Sub Surface 131, !- Fenestration Surface Name 59
Sub Surface 116, !- Fenestration Surface Name 60
Sub Surface 120, !- Fenestration Surface Name 61
Sub Surface 124, !- Fenestration Surface Name 62
Sub Surface 129, !- Fenestration Surface Name 63
Sub Surface 132, !- Fenestration Surface Name 64
Sub Surface 121, !- Fenestration Surface Name 65
Sub Surface 127, !- Fenestration Surface Name 66
Sub Surface 122, !- Fenestration Surface Name 67
Sub Surface 119, !- Fenestration Surface Name 68
Sub Surface 136, !- Fenestration Surface Name 69
Sub Surface 134, !- Fenestration Surface Name 70
Sub Surface 117, !- Fenestration Surface Name 71
Sub Surface 118, !- Fenestration Surface Name 72
Sub Surface 130, !- Fenestration Surface Name 73
Sub Surface 34, !- Fenestration Surface Name 74
Sub Surface 13, !- Fenestration Surface Name 75
Sub Surface 128, !- Fenestration Surface Name 76
Sub Surface 123; !- Fenestration Surface Name 77
