I have to model a Glicol Cooling system where the Glicol supply temperature is around -5°C. The IDF editor tells that the Water Coil works only for temperature above zero. There is a way to overcame this limitation?
| 1 | initial version |
| 3 | retagged |
| 4 | retagged |
