Hi
Im having problems with Open studio Legacy installation.
operating system : Windows 7 ultimate SP1 -- 32 bit
I performed the installation as follows:
- Sketch up 2015 pro 32 bit
- Energy plus 8.2 (EnergyPlus-8.2.0-8397c2e30b-Windows-x86_64) * 32 bit and 64 bits in the same installer I assume
- Open studio plugin (OpenStudio-1.0.11 414) 32 bit
- Open studio legacy (OpenStudio-1.6.0.1229eac298-Windows) 32 bit
all install directory by default in "C"
In 4, during installation a problem occurs. (see pic: https://www.dropbox.com/sh/wk0iocvhv7mkzng/AADEqUeVNMQDmptxUdSQ4zPMa?dl=0)
If my PC arquitecture is 32 bits i cant install sketchup 64 bits. I dont know what is wrong I dont understand the message: "32 bit Open studio is incompatible with 64 bit Sketchup 2015 Open studio plug in will not be installed"
Please help.
I tried not installed E+, step 2. (OpenStudio 1.6.0 works with EnergyPlus 8.2.0 Update 1, which is now bundled with the OpenStudio installer. It is no longer necessary to download and install EnergyPlus separately.)
but the same problem occurs.
Thanks
