Hi,
I am trying to get the zones load break down using "Zone Report" measure, but every time I use the measure I get the the below error. I tried different versions of the measure, also tried to download the measure and add it to "my measures" and use it from there. I am not sure if this is because the measure is not compatible with the OpenStudio version 2.6 that I am using, or if there is something should be done before using this measure?
Thank you,
