Hello, I am learning to understand how the heat gain calculation happened in Energy Plus, and I am reading in the ASHRAE Handbook of Fundamental that the instantaneous space sensible load should be same with the heat removal rate of conditioning equipment.
I am looking at the zone air heat balance to look at each components contribution to the zone sensible load.
Based on the observation in my result, the Zone Air Heat Balance System Air Transfer Rate number match with sum of
Zone Air Heat Balance Internal Convective Heat Gain RateZone Air Heat Balance Surface Convection RateZone Air Heat Balance Interzone Air Transfer RateZone Air Heat Balance Outdoor Air Transfer Rate
minus the Zone Air Heat Balance Air Energy Storage Rate.
Based on the sentences, what I understand is that the zone air heat balance system air transfer rate should be match with the zone cooling coil sensible cooling rate, is that correct?
However, when I check the number, there is always a constant difference between those number in each day. Am I using the right parameter to compare? Or there is any parameter that I need to check in order to have the same number with system air transfer rate?
Thank you
