I want to change the initial condition of the simulation. (like the indoor temperature at the very beginning) But I found this from the documentation:
EnergyPlus “runs” the first day of the environment (starting with a set of hard-coded initial conditions) until the loads/temperature convergence tolerance values are satisfied or until it reaches “maximum number of warmup days.
Does it mean there is no chance I can modify the initial condition?
