OS Error:"The Flow Fraction for Surface x in Surface Group LOW TEMP RADIANT VAR FLOW nameCEILINGS is too low * Flow fraction of 3E-004 is less than minimum criteria = 1.000000E-003''
I get the error for each radiant ceiling that I inserted in different thermal zones in my model. I cannot find the field in open studio in which I can set the corresponding values to higher than 0.001. Has anyone experienced this problem before? Do you know how to fix it? Thank you in advance for your help and time!
