Dear all,
I have run the PAT successfully and the results does not appear in the window. Is there a java or similar update I need to install in order to view results and export from the interface?
Thank you and kind regards
| 1 | initial version |
Dear all,
Dear all,
I have run the OS PAT successfully and the results does do not appear in the window. Is there a java or similar update I need to install in order to view results and export from the interface?
Thank you and kind regards regards
Dear all,
I have run OS PAT successfully and the results do not appear in the window. Is there a java or similar update I need to install in order to view results and export from the interface?
