Hi
I'm using EnergyPlus to model a TABS system using ZoneHVAC:LowTemperatureRadiant:ConstantFlow. For Temperature Control Type I'm using the OutdoorDryBulbTemperature. Is it possible to use 2 control parameters for my TABS system? E.g.: I want my TABS to be active in winter when the OutdoorDryBulbTemperature is below 8°C AND if the Operative Temperature is not above 18°C. Thanks in advance!
