Hello everyone, I have a question about OS: building. When I select the inspector option and I'm going to view the whole building, this option appears. I would like to know if I need to define the space type name, because when I insert the loads of the equipment in the zones, after inserting each zone separately, I need to insert for the whole construction, if I use space type name. So, I do not know which value to use. As my building is of medium size, I put the WholeBuilding - md office option. Is this procedure correct? Thank you
https://imgur.com/tyqhVkr
