Does light shelf work like a shading object limiting solar energy to hit and transmit to windows thus affecting window solar gains?
Does light shelf have reflectance( which is equal to reflectivity ) that allows light to be reflected to the clerestory into the ceiling onto the work-plane?
I wanted to investigate illumination and daylighting by light shelves in EnergyPlus instead of using Radiance since I will also be assessing its energy impact on the building.
