I'm trying to setup a windows server 2012 r2 running openstudio-server to run an algorithmic analysis from the parametric analysis tool. The only instructions I've found require docker (there is mention of other installation instructions without docker, but I can't find them), but docker is not compatible with windows server 2012 r2.
https://forums.docker.com/t/windows-server-2012-r2/24267/3
Other than paying to upgrade our server's OS, paying for use of the Amazon cloud, or running docker inside a VM (still trying to be fast), are there any up to date instructions for installing openstudio-server without the use of docker?
