Now observe this result
First Column Represents window opening factor, second column represents Zone Temperature, Third column represents Zone Humidity Fourth Column Represents OA Temperature Fifth Column Represents OA Humidity Logic that I applied in the EMS programme: open the window when the Zone air temperature is (24-28) and OA is less than during that time. secondly, when the zone air absolute humidity and out side air humidty both are less than 0.012 kg/kg
My query: observe the column No 6, 7, 8......when the logic is not working, window opening factor is 0 (columns 1 to 5)
when the logic is working openinig factor is 1 in 6 and 7th column. Now explain me one thing..now the window is opened in 6th time step. what is the result of opening window? is it the seventh time step?
is it this way: the condition at the beginning of 6th time step will allow the air to enter and the result is seventh time step ......Now again, the condition at the beginning of seventh time step will allow the air to enter and the result is seen in eighth time step...Now, the condition at the beginning of eighth time step (which formed because of seventh time step) is not satisfying and hence the window is closed.
0 22.32776642 0.007519783 25.8 0.006619171
0 22.80108552 0.007215516 26.4 0.00686081
0 22.93388437 0.007143305 26.5 0.006465984
0 24.04453626 0.006887364 26.2 0.006565319
0 24.19472665 0.006820452 25.4 0.006462287
1 24.48299625 0.006633287 24.3 0.006811902
1 24.2551892 0.006731865 22.9 0.00678226
0 23.69316177 0.00680298 21.6 0.006910261
0 23.90553343 0.006904547 20.3 0.006373917
0 23.41065169 0.006793053 19.4 0.006166049
0 22.63518318 0.006573069 18.6 0.005997377
How to read this? whatever I told is it the right way?
