I am using the RunAllOSMs.rb Ruby script from the example script files to run an OpenStudio file from the command line. When I do this, the OpenStuido post process Report.xml file is generated, however when I open up OpenStudio after the simulation completes, the OpenStudio Report is not visible. Is there a way that the OpenStudio Report can be shown after running an OSM from the command line?
