Multi-storey Geometry Error – Merging of Floors
I've been trying to generate geometry of a 4 storey building for the past one month. Unfortunately, every time I save and close the file in .osm, the floors overlap resulting in recreating the geometry from scratch.
The work flow used is :
Cad Drawing with reference as core - Export as Dxf - Created a new space in open studio - Extrude using "Set attributes with building storey" - Save .osm file
I would appreciate any help to sort out my issue as my deadline is soon :D!
Cheers
Cheers
Cad Drawing with reference as core - Export as Dxf - Created a new space in open studio - Extrude using "Set attributes with building storey" - Save .osm filefile image description
CheersCheers!
Cad Drawing with reference as core - Export as Dxf - Created a new space in open studio - Extrude using "Set attributes with building storey" - Save .osm file file
Before Closing the file with completed Geometry(.osm) - ----- After opening the same file in osm
Cheers!
Before Closing the file with completed Geometry(.osm) - ----- After opening the same file in osm(.osm)
Cheers!
Before Closing the file with completed Geometry(.osm) - ----- After opening the same file in (.osm)
Cheers!
Cheers!
Cheers!
Cheers!
Cheers!
