Hello, I am looking to get a geometry through the resstock build program. I am looking for an entirely mini-split heated/cooled home with a slab foundation. In order to fully accomplish the model, I wish to have the ducts absent from the house with the mini-splits directly discharging into space. In the ducts options, I do not see a 'None' option that is available for certain other parameters. There is an "option = In Finished Space" towards the end. Does that substitute for absent Ducts inside a home? If not is there a workaround to achieve the said config?
Thanks
