I would like to simulate the ground temperature and the heat transfer floor/ground with Kiva. My slab is only concrete (conductivity = 2), 20cm, no insulation. The ground is sand.
Additional informations : My project is in Indonesia and my inside temperature is set to 24 C for all the year.
I have used the kiva software, have set the good parameters (I think), the good weather file. I get what follow :
I dont know if these results are corrects but they are not inconsistent in my opinion.
Now, I have tried to use Kiva in E+, I followed the ZoneCoupledKivaSlab, changed the outside boundaries conditions, deleted the sitegroundtemperature : buildingsurface, but when I simulate my model, it says that my cooling load is equal to 0W for all the rooms at the ground floor. So it means, my ground cools completely my rooms. No need AC. Practical but not very true I think.
First In E+, what others parameters I need to set to have some consistent results ? What did I forget or what wrong parameters did I set ?
And In your opinion, my results with Kiva software seems consistent ? Can I use these temperatures in sitegroundtemperature : buildingsurface ?
Thank for your help
