I am setting up a Openstudio proposed building model with DOAS and fan coil units according to [previous question]. (https://unmethours.com/question/16262/problem-with-fancoil-modeling/)
All the parameters for the fan coil unit are all set up according to the designed sechdule. There is one of the fan coil cooling coil setting, which is showed in the following picture.
The err shows the following lines:
Here are linkes for the folder and the OSM file for this model.
https://drive.google.com/open?id=1IdiZ2sgES_-T-2a6MNv69kjTxP5BJFgK
https://drive.google.com/open?id=16XF9j5TxPqblOgTQR47ihk0TIgRbC6Uz
Thanks in advance! I have tried my best to solve this without any clue for two days...
