I have been working on expanded .idf files to fix the iplv value for chillers, but I have noticed that the values only come close to the desired iplv value and needs subsequent iterations for correction. This is a problem for cases where the simulations take a lot of real time. Is there a way to enter the correct exact coefficient that gives the desired output ?
