I added a meter using the 'AddMeter' measure with a frequency set to monthly. however, when I used the 'ExportMetertoCSV' measure, there was no option to set the frequency to monthly. The 'ExportMetertoCSV' measure only seems to give an option for hourly or zone timestep frequency. Is there any other measure that I can use to export monthly data from the meter I added? Or any other way to access the data from the meter?
