I am getting cooling rate in the month of January even the room temperature are below the cooling set point.
| 1 | initial version |
| 2 | retagged |
| 3 | None |
I am getting cooling rate in the month of January even when the room temperature are is below the cooling set point.
| 4 | retagged |
I am getting cooling rate in the month of January even when the room temperature is below the cooling set point.
| 5 | retagged |
