Hi there! I have created a model on Sketchup with Open Studio. How can I avoid to lose the data in the switch between osm and idf? For example, I created a natural vented cavity with idf editor. Then, if I need to change the model with graphic input (as I use Sketchup) I lose that information. Now.. the natural vented cavity is actually the most boring input, overall when you have about 20 surfaces with it, how can maintain the information?
