Hi, I've been receiving the following error and was wondering if there was any recommended workflow for correcting it. I was able to resolve another instance of the same error in Sketchup (though it took quite a few tries). It seems that when I attempt to do anything to the surfaces listed below, the model crashes and advises me to close and save a backup. I looked into directing editing the .osm file, but it seems that values aren't displayed to enough precision for a discrepancy between vertices to show. Any help would be greatly appreciated:
* Warning * CalculateZoneVolume: The Zone="0924-CORRIDOR-TZ" is not fully enclosed. To be fully enclosed, each edge of a surface must also be an edge on one other surface. * ~~~ * The zone volume was calculated using the floor area times ceiling height method where the floor and ceiling are the same except for the z-coordinates. * ~~~ * The surface "SURFACE 1614" has an edge that is either not an edge on another surface or is an edge on three or more surfaces: * ~~~ * Vertex start { 32.7536, 2.5467E-002, 35.3568} * ~~~ * Vertex end { 33.9728, 2.1372, 35.3568} * ~~~ * The surface "SURFACE 1617" has an edge that is either not an edge on another surface or is an edge on three or more surfaces: * ~~~ * Vertex start { 33.9728, 2.1372, 35.3568} * ~~~ * Vertex end { 35.0333, 3.9739, 35.3568}
