My issue is, I have a big heat transfer between my room and the ground.
I have set the "site ground temperature :building surface" at 24 C for all the months. I have tried Slab which give me approximately the same temperature (around 24 C).
I am surprised because the temperature in my room is also 24 C and when I check the result in zone loads compenent, I have - 4000 W.
The surface of my room is 270 m2. I find this a bit much.
My floor is only concrete, no insulation. I have set all the parameters correctly (U value, thickness, ...)
I did something wrong ? What are the habits usually for ground temperature ?
Thank for your help
