i'm working with energyplus. Someone can tell me, why the surface inside face conduction heat tranfer is less than surface outside face conduction heat tranfer ?
if I'm losing heat from the inside by conduction (inside face conduction heat tranfer). That loss should be greater than the flow of heat that reaches the outside by conduction (outside face conduction heat tranfer), since a part is stored. However, I do not see that in the results
