I see a few options in EnergyPlus to model a single-zone heat pump with variable air volume, but I haven't found a way to do it in OpenStudio. In EnergyPlus the AirloopHVAC:UnitarySystem object has an option for control type SingleZoneVAV. Or multiple stages of airflow can be represented with the "Design Specification Multispeed" Object Type. But neither of these appears to be available as an option in the OpenStudio interface.
Before I go outside OpenStudio, I wanted to see if anyone has a successful method for representing this system type within OpenStudio. Variable flow has been required by code for some time now for systems larger than 5 tons.
