** Severe ** Invalid Output:Variable or Output:Meter Index Key Name ={220AFAC8-F9FE-4FD1-89B0-38DD715C7363}
~~~ ** For Output:Variable or Output:Meter = SYSTEM NODE SETPOINT TEMPERATURE
~~~ ** Entered in EnergyManagementSystem:Sensor=ENERGY_MANAGEMENT_SYSTEM_SENSOR_1
~~~ ** Unique Key Name not found.
Fatal ** Errors found in processing Energy Management System input. Preceding condition causes termination.
This is what I get as output from the simulation lauched in Open Studio. I tried to insert a new variable by means of the AddOutputVariable measure, as suggested by an answer to a similar question, but I'm not sure if it was the solution to my problem and if I did that correctly. Unfortunately all the answers I found refer directly to Energy Plus input and not to Open Studio, so I'm really struggling to find the corresponding elements. I'm quite new at Open Studio, so it could be a basic question. I hope someone can help me. Thanks in advance.
