Hi
The Coil Final Gross Total Capacity is 25799.329 Watts. And the Coil Final Reference Air Volume Flow Rate is 1.038939 m3/s. Dividing 1.038939 by 25799.329 gives 4.02700008E-5. But why does the warning in energyplus say "Air volume flow rate per watt of rated total cooling capacity is out of range at 6.741E-005 m3/s/W"
