I have a residential building that I would like to heat with a gas burned CV system, heating up the different spaces and thermal zones with hot water running through wall mounted radiators, typical construction in the Netherlands. This same gas burned CV is used for heating up the domestic hot water supply. How can I model that in OpenStudio ?
