OpenStudio v2.4.0 > Sketchup PlugIn
Appear to be having difficulty getting User Scripts to load in the Sketchup Plugin. The 'Load User Scripts' also doesn't appear to help in the matter. I have located the right directory, as my 'new folder' shows up in the drop down menus: Extensions > OpenStudio User Scripts > zCustom Scripts> ....then this is empty. Even If I copy/paste one of the preloaded user scripts into the folder. So, what am I missing here?
Second / follow on. It appears that the OS plug-in doesn't appear in my Roaming profile where all my other SU Extensions live. How does OS plug in know its to be loaded then? Is it possible to switch between versions of the OS SU plugin if this can be load/unloaded?
