In looking through the openstudio-server code, it seems like there are four possible status enumerations for any datapoint:
completed: which means it is done with that datapoint queued: which means it is in the pipeline to run started: which (i think) means the simulation is in progress but not completed na: ???
when would you get an na? And is this a good sign that you should abort the entire analysis?
