Hello Everyone, I'm trying to get the AC Window type working well on my model. The problem is the consumption of the base-model still too low compare to the actual building. Even though I used E+ template “WindACAuto” from the example files, I still don’t get the right consumption of the actual building. I added 3 more zones after I added the template in order to put one AC window unit in each conditioned zone of the building. HELP APPRECIATED! THANK YOU.
