Do anyone has tried to export the report from the Design Builder,?I did a test and found that “Walls+Ground Floors+Roofs” value in the DB report is equal to“:Zone Opaque Surface Inside Faces Total Conduction Heat Gain Rate—Zone Opaque Surface Inside Faces Total Conduction Heat Loss Rate ",as also as“Surface Inside Face Conduction Heat Transfer Rate ” . But I wonder that why it is nothing to do with “ Outside Face Conduction ”,I think it should be equal to Surface Average Face Conduction Heat Transfer Rate . And I still can't export "Zone Opaque Surface Outside Face Conduction Gain"
