I have done a simulation with a vrf system and 4 vrf zones. When I simulate my model, I have this warning message which appears :
"GetDXCoils: Coil:Cooling:DX:VariableRefrigerantFlow="BUILDING 20 SECOND FLOOR ROOM 4 VRF COOLING COIL" curve values
Cooling Capacity Ratio Modifier Function of Temperature Curve Name = BUILDING 20 SECOND FLOOR ROOM 4 VRF COOLING COIL CAP-FT output is not equal to 1.0 (+ or - 10%) at rated conditions.
Curve output at rated conditions = 1.136"
Same message for the VRF system and for each of my zones I have a result but I would like to know how to fix it and if there is an impact on my result ?
