EnergyPlus Runperiod setup
I have csv data file which has data from 3/3/2017 to 3/3/2017. When I set this in Run Period as start month 3 and start day 3 and end month 3 and end date 3, energyplus is unable to perform on whole year simulation. The standard procedure is to use 1/1 as start month and date and 12/31 and end month and date. Can someone suggest a way to solve my issue?
I have csv data file which has data from 3/3/2017 3/3/2016 to 3/3/2017. When I set this in Run Period as start month 3 and start day 3 and end month 3 and end date 3, energyplus is unable to perform on whole year simulation. The standard procedure is to use 1/1 as start month and date and 12/31 and end month and date. Can someone suggest a way to solve my issue?
