my name is ALI , I would like to simulate a thermal chimney by the air flow network how-ever I could not understand what kind of settings of the air flow network have to be installed to simulate a dependent bouyancy effect device .
the next problem relates to the output variable name , actually I need to have volume flow rate of the thermal chimney from the outlet but i do not know what kind of variable name helps to reach the result. ALI_SALEHI1986@YAHOO.COM
