analyse data viewer
I want to analyze the results obtained by data viewer but I saw that there is a contradiction between the end use graph and the results of dview, normally if I do the sum of annual consumption of heating and cooling, I must fell on the total consumption that is in end use graph but in dview the monthly consumption is very small as shows the figures below
analyse data viewer
analyse data viewer
analyse data viewer
I want to analyze the results obtained by data viewer but I saw that there is a contradiction between the end use graph and the results of dview, normally if I do the sum of annual consumption of heating and cooling, I must fell on the total consumption that is in end use graph but in dview the monthly consumption is very small as shows the figures belowimage description(/upfiles/15335549729494664.jpg)
analyse data viewer
I want to analyze the results obtained by data viewer but I saw that there is a contradiction between the end use graph and the results of dview, normally if I do the sum of annual consumption of heating and cooling, I must fell on the total consumption that is in end use graph but in dview the monthly consumption is very small as shows the figures belowimage description(/upfiles/15335549729494664.jpg)image description
