Hello guys,
I would kindly ask for some help.
What is the difference between SketchUp and SketchUp plug-in? I mean, I really don’t understand these 2 sentences:
If you make changes and save them in the OpenStudio application, be sure to RELOAD the model in the SketchUp Plug-in before you make any changes in SketchUp.
How do I reload it? Does it mean that if I make some changes in OpenStudio I should save for example as test123.osm and same with sketchup plug-in test123.skp?
You should also RELOAD the model in the OpenStudio application if you have made additional changes in SketchUp.
How do I reload it here?
Thanks in advance, AZ
