Hi
I have set up a EMS that switches between several Construction:ComplexFenestrationState, in order to model dynamic solar shading (drawing inspiration from the example file ThermochromicWindow.idf). To test the validity of the EMS approach I have created a simple comparison:
idf 1) Assigns ONE Construction:ComplexFenestrationState to all windows in the model by Construction Name.
idf 2) Assigns ONE Construction:ComplexFenestrationState to all windows in the model by a EMS that overides the existing constructions.
(all the relevant objects are at the bottom of the files)
This should in my mind produce the excact same results, however there are some big differences in the output. Does anybody have an idea as to why?
