plz I have probleme to understanding the graph results in beopt.
plz I have probleme to understanding the graph results in beopt. i have heating and cooling and heating fan/pump and cooling fan/ pump. what is different between cooling and cooling fan pump (in the option I choise air source heat pump wich provide cooling and heating)
click to hide/show revision 2
None
plz I have probleme problem to understanding the graph graphic results in beopt. i I have heating and cooling and heating fan/pump and cooling fan/ pump. what What is different the difference between cooling and cooling fan pump (in the option I choise choose air source heat pump wich provide cooling and heating) heating).
click to hide/show revision 3
None
I have problem to understanding the graphic results in beopt. I have heating and cooling and heating fan/pump and cooling fan/ pump. What is the difference between cooling and cooling fan pump ? (in the option I choose air source heat pump wich provide cooling and heating).
click to hide/show revision 4
None
