Hi guys
I'm trying to create a EnergyPlus measure to import the BSDF-idf input from LBNL WINDOW. Most of the functionality needed can be found in the BCL measure "inject_idf_ojbects". However the measure chages the formatting of all the matrix data (to something that cannot run) - example:
I think it comes down to that one of these functions
source_idf = OpenStudio::IdfFile::load(OpenStudio::Path.new(source_idf_path)).get workspace.addObjects(source_idf.objects)
uses "," to destinguise a new line and not "\n" as it should in this case.
Does anybody have an idea of how to correctly import the BSDF-idf using a EnergyPlus measure?
Cheers Tobias
