Hi
It looks like the IPLV calculated for my chiller is not at AHRI test conditions,
The error reads
** Warning ** Chiller:Electric:EIR = CHILLER ELECTRIC EIR 1: Integrated Part Load Value (IPLV) calculated is not at the AHRI test condition.
** ~~~ ** Check limits in Cooling Capacity Function of Temperature Curve, Curve Type = BIQUADRATIC, Curve Name = CURVE BIQUADRATIC 47
** ~~~ ** Check limits in EIR Function of Temperature Curve, Curve Type = BIQUADRATIC, Curve Name = CURVE BIQUADRATIC 48
Is there a work around for this issue or should I change my chiller ? Thank you
