Hello,
I am trying to model DOAS which has seasonal OA mass flow. To model this, I am trying to use SetpointManager:Scheduled - Control Type MassFlowRate with which flow can be controlled in different seasons. However, I see constant airflow after applying the SetpointManager with desired Mass flow Rate as described in I/O file.
Any pointer will be appreciated in this regard.
Thanks,
