asked 6 years ago
Siv's avatar
The cooling load of my facility is 217 kW. The coil load is 636 kW. How can I see the components of the coil load to verify that the sum of the facility loads + other load is 636 kW. I would like to know the other components of the coil load
The cooling load of my facility is 217 kW. The coil load is 636 kW. How can I see the components of the coil load to verify that the sum of the [facility load + other loads] is 636 kW. I would like to know the other components of the coil load.
The cooling load of my facility is 217 kW. The coil load is 636 kW. How can I see the components of the coil load to verify that the sum of the facility loads [facility load + other load loads] is 636 kW. I would like to know the other components of the coil load
