I'm going to control airloop by air relative humidity... There are a zone and an air loop containing 1 humidifier and 1 fan. The fan is always on and I try to turn it off when humidifier is off...
how can I turn loop off?
I try to use EMS and turn the fan off when humidifier power is 0 but it didn't work...and also I've tried to change loop availability by using a sensor for humidifier power but it doesn't work also... what must I do?
