I want to calculate the cooling load for a building when changing some of its elements like the wall and window constructions. I want to know the results for all possible combinations. These will be more than 3000 combinations. I made the measurements in PAT2 but I do not know which sampling (algorithmic) method to use when making the calculations on the cloud so I can have all the combinations. Also, I am not sure if I should use the Discrete or Pivot setting when changing the wall construction in a measurement. Thanks.
