I have a number of very old eQuest models (5+ yrs) that need to be updated for the final architectural design. Typical practice would dictate going back into wizard mode for geometry editing, but I’ve become inspired by EnergyPlus Python/Sketchup workflows and have decided to instead try and use some combination of the two.
In many cases, I can accomplish this without adding any spaces or adding any vertices, so I’m not concerned with adjacencies/boundary errors or the general eQuest/DOE-2 side, and I already have a module that imports polygons from an input file into a usable array of coordinates within Python.
My goal is to import this array into Sketchup (or similar), change the location of selected vertices within it, and then reimport the new vertices into the model.
My question is: Are there any commonly-used tools/modules for importing coordinate pairs into Sketchup, changing the coordinates within it, and then exporting the same coordinates back into a text-based format? I’m thinking some kind of JSON or GBXML interface, but I’d trying to avoid too much wheel-reinvention.
