I've modeled a zone and tried to control some HVAC by EMS...but it doesn't report correct answer... to examine what I did, I've removed every thing but my zone. Then write following Simple code, But I observe same thing in variable report:
=========== CLASS: SCHEDULE:CONSTANT ===========
Schedule:Constant,Test,Discrete,0;
=========== CLASS: ENERGYMANAGEMENTSYSTEM ===========
EnergyManagementSystem:Sensor,
OutdoorTemp, !- Name
Environment, !- Output:Variable or Output:Meter Index Key Name
Site Outdoor Air Drybulb Temperature; !- Output:Variable or Output:Meter Name
Test_Loop, !- Name
TEST, !- Actuated Component Unique Name
Schedule:Constant, !- Actuated Component Type
Schedule Value; !- Actuated Component Control Type
Test Program, !- Name
InsideHVACSystemIterationLoop, !- EnergyPlus Model Calling Point
FanControl; !- Program Name 1
FanControl, !- Name
IF (OutdoorTemp < 16.0), !- Program Line 1
SET Test_Loop = 5.0, !- Program Line 2
ELSE, !- A4
SET Test_Loop = Null, !- A5
ENDIF; !- A6
=========== CLASS: OUTPUT:VARIABLE ===========
Output:Variable,Test,Schedule Value,Hourly;
I observed following report that demonstrate weird report in the boundary temperature (16 degree): (I've changed Calling Point but the answer is same)
Date/Time Temperature TEST:Schedule Value
05/15 04:00:00 18.14 0
05/15 05:00:00 16.05 2.5
05/15 06:00:00 14.05 5
05/15 07:00:00 13.8 5
05/15 08:00:00 16.51 1.67
05/15 09:00:00 20.46 0
