After successfully coupling CONTAM and Energy+, the simulation dynamically calculates the infiltration and temperature. However, the infiltration loads in Energy+ output file is still zero because CONTAM exported IDF contains a design flow rate of zero in ZoneInfiltration:DesignFlowRate. Does CONTAM not calculate the design flow rate for infiltration based on Design day information ?
