I have a working model built from some EP example files.
In my PlantLoop for heating I have a Storage tank for preheating, and a WaterHeater:Mixed to provide additional heat. I want to compare this scenario with my baseline scenario, in which I have a Boiler:HotWater for heating.
For this purpose I'm trying to replace the WaterHeater by a Boiler. However, I can't get this to work. I suspect some issue with setpoints, since there is flow through the Boiler, it just doesn't heat. Also, the WaterHeater has a field called 'Setpoint Temperature Schedule Name', whereas the Boiler doesn't.
I tried fiddling around with the setpoints. Also I've moved the Boiler to the same branch as the Storage Tank, without result.
How can I get my Boiler to heat to 50C?
Working with WaterHeater:Mixed
